Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1928824members
1242657discussions
Community Activity
Configuring NAT overload with vrf lite on a CAT9K
Good day;Need help with how I can configure NAT overload with an existing vrf on a CAT9K_IOSXE V16.12.  This is what I am struggling with, I currently have a vrf called AWSDX-S3.  Now what I am trying to do is I have added a L2 SW and ran trunk ports...
gurowar by Level 1
  • 288 Views
  • 12 replies
Extremely slow and poor overall WiFi quality with C9130AXI
Recently swapped our 3802i APs for all C9130AXI to get the WiFi 6 capability. Have noticed very poor performance overall. Only change has been with the APs, nothing else. The controller remained to be an AIR 3504 and the switch is a Catalyst 3850 UPo...
NexCyb by Level 1
  • 1 Views
  • 0 replies
Cisco Secure Client CVE-2024-20337
Following upgrading to upgrading to 5.1.2.42 to fix the vulnerability CVE-2024-20337Within Microsoft Defender this is still flagged as vulnerability for the CVEIt appears to refer to a component of the install:C:\Program Files (x86)\Cisco\Cisco Secur...
ansto by Level 1
  • 219 Views
  • 6 replies
Recording Jabber - Overlapping Voices
Hello, I'm having this situation:In the call center we have PCs with softphones installed (Jabber) that replicate the traffic to a recorder in another site.Randomly, we are seeing high levels of Jitter in the flow that is replicated to the communicat...
Help with routing vlans
Can someone tell me how do I do routing here ? it does not matter if it is static or dynamic I just want to ping same vlans and also I dont want to have different vlans to be pinged
CUCM HUNT GROUP AND INTERCOM CALLS
Hi to allMy question is very simpleIntercom working fine , but the issue is that you can call only one intercom phoneWhat is the requirement if i want to perform an intercom call to a multiple phonesDoes this work with Hunt group?Regards
Resolved! ASA-AWS unable to ssh into new instance
This question has been asked a couple of other times, but no one has ever answered it. I am bringing up an AWS instance running the Cisco ASAv 9.9.2.1 application, but I am unable to ssh into the resulting instance.I am following the instructions pro...
opencCnnect vpn cache?
Hello. If you have a minute, could anybody help with possibly diagnosing this? Monday 1 AM After logging in to network over openConnect vpn (I wanted to check an smtp server to ensure it was running before work week started). This server was inaccess...
tgriffit60 by Community Member
  • 37 Views
  • 0 replies
Resolved! Very low upload speed, download speed normal
This started about last week; no changes have been made to any of the switches. We're a small business so not very many employees, but we're a TV station so we have multitudes of servers.Our Primary ISP is a 2gig by 2gig connection, same as our Secon...
MLIT by Level 1
  • 433 Views
  • 3 replies
