Warning message
Jabber Guest Call issue class java.net.SocketTimeoutException
Mar 5th, 2015
Hello, team!
I have problems with JG configuration.
As often all looks right but works wrong.
EXP-E,-C versions X8.2.2
JG version 10.5
CUCM version 10.5
Client connect to system. But when I press Call it just try to call.
i have check JG logs and found 404 error.
-- 2015-03-04 18:26:59.949 INFO [58d2000] - [csf.httpclient][getResponseCode] Http Response Code = [404] for request [11].
As I understand, it's internal error. On Exp-E and Exp-C I have no in Search History.
What part of JG can be wrong?
mrmccann Fri, 03/06/2015 - 15:23
  • Cisco Employee,
Are you testing with web client or iOS client?
When you press Call, do you get any error on the screen?  Could you post a screenshot of the error?  If no error, then what happens?
Also, what deployment model are you following, from install & configuration guide?
Mike
Valeriy Tarazanov Wed, 03/11/2015 - 01:28
Hi, Mike!
Web client. Chrome.
I have fix this problem. It was exist in case of wrong operation firewall configuration.
I have no connectivity JG ->Exp-E. JG faced 404 error and Win client drops in Java error. I think it's problem of Java module. It haven't error description on this error.
At this moment i have face problem with no audio/no video call.
