03-05-2015 05:18 PM - edited 03-18-2019 04:08 AM
I have a MCU 5320 and some endpoints SX20, SX80, MX800...
When I create a meeting room on the MCU, some or all participants are disconnected suddenly after 30 -> 60 minutes.
Are there any people having a solution for the issue?
Thanks.
03-08-2015 07:03 PM
Do you have some more information about your setup, the more verbose the better, like
how is your deployment, do you have any kind of call control or a direct call setup?
What protocol do you use, sip, h323? which software versions do you run?
How does the network setup look like, how is the call flow?
In general such kind of disconnects are often caused by NAT routers, firewalls, ALGs, ...
short everything what tries to mangle with the h323 or sip communication
03-08-2015 07:22 PM
Hi Koch.
I use only H.323 protocol to call direct from MCU to Endpoints.
MCU version is 4.5
Endpoints version is TC 7.1
Thanks.
03-08-2015 07:43 PM
Check your network components, something seems to interfere with the signaling
