Hi everyone,
im fighting with Cisco 866VAE-K9 for few days. I have got ADSL2+ line in Cisco, i can ping anything from router (like 8.8.8.8 or www.google.com), test of connection in CCP runs successfully, but i cant acces web pages from LAN computers. From LAN i can ping to any IP adress in internet (like 8.8.8.8), but i cant ping or access domain names of web pages (like www.google.com). I know there is probably something wrong in my config, but after 2 days of googling i cant find where the problem is. Can anybody help?
Here is my running config:
Building configuration...
Current configuration : 8181 bytes
! Last configuration change at 11:31:15 UTC Fri Mar 6 2015 by admin
version 15.2
no service pad
hostname cisco_866vae
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 xx
enable password xx
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
wan mode dsl
ip port-map user-protocol--1 port tcp 3500
ip name-server 8.8.8.8
ip cef
no ipv6 cef
parameter-map type protocol-info yahoo-servers
server name scs.msg.yahoo.com
server name scsa.msg.yahoo.com
server name scsb.msg.yahoo.com
server name scsc.msg.yahoo.com
server name scsd.msg.yahoo.com
server name cs16.msg.dcn.yahoo.com
server name cs19.msg.dcn.yahoo.com
server name cs42.msg.dcn.yahoo.com
server name cs53.msg.dcn.yahoo.com
server name cs54.msg.dcn.yahoo.com
server name ads1.vip.scd.yahoo.com
server name radio1.launch.vip.dal.yahoo.com
server name in1.msg.vip.re2.yahoo.com
server name data1.my.vip.sc5.yahoo.com
server name address1.pim.vip.mud.yahoo.com
server name edit.messenger.yahoo.com
server name messenger.yahoo.com
server name http.pager.yahoo.com
server name privacy.yahoo.com
server name csa.yahoo.com
server name csb.yahoo.com
server name csc.yahoo.com
parameter-map type protocol-info msn-servers
server name messenger.hotmail.com
server name gateway.messenger.hotmail.com
server name webmessenger.msn.com
parameter-map type protocol-info aol-servers
server name login.oscar.aol.com
server name toc.oscar.aol.com
server name oam-d09a.blue.aol.com
crypto pki trustpoint TP-self-signed-2886901321
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2886901321
revocation-check none
rsakeypair TP-self-signed-2886901321
crypto pki certificate chain TP-self-signed-2886901321
certificate self-signed 01
controller VDSL 0
class-map type inspect match-any SDM_BOOTPC
match access-group name SDM_BOOTPC
class-map type inspect match-any ccp-cls-protocol-p2p
match protocol edonkey signature
match protocol gnutella signature
match protocol kazaa2 signature
match protocol fasttrack signature
match protocol bittorrent signature
class-map type inspect match-all ccp-cls--1
match access-group name all
class-map type inspect match-all ccp-cls--2
match access-group name all1
class-map type inspect match-any ccp-cls-protocol-im
match protocol ymsgr yahoo-servers
match protocol msnmsgr msn-servers
match protocol aol aol-servers
class-map type inspect match-any SDM_SSH
match access-group name SDM_SSH
class-map type inspect match-any SDM_HTTPS
match access-group name SDM_HTTPS
class-map type inspect match-all SDM_GRE
match access-group name SDM_GRE
class-map type inspect match-any SDM_SHELL
match access-group name SDM_SHELL
class-map type inspect match-any sdm-cls-access
match class-map SDM_HTTPS
match class-map SDM_SSH
match class-map SDM_SHELL
class-map type inspect match-all sdm-access
match class-map sdm-cls-access
match access-group 101
policy-map type inspect ccp-policy-ccp-cls--1
class type inspect ccp-cls--1
pass
class class-default
drop
policy-map type inspect ccp-policy-ccp-cls--2
class type inspect ccp-cls--2
pass
class class-default
drop
zone security out
zone security in
zone-pair security sdm-zp-in-out source in destination out
service-policy type inspect ccp-policy-ccp-cls--1
zone-pair security sdm-zp-out-in source out destination in
service-policy type inspect ccp-policy-ccp-cls--2
interface Loopback0
ip address 192.168.100.1 255.255.255.0
zone-member security in
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
pvc 8/48
oam-pvc manage
pppoe-client dial-pool-number 1
interface Ethernet0
description $ETH-WAN$
no ip address
shutdown
pppoe-client dial-pool-number 2
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
description $ETH-WAN$$FW_OUTSIDE$
ip address dhcp client-id GigabitEthernet1
ip tcp adjust-mss 1412
shutdown
duplex auto
speed auto
interface Vlan1
description $FW_INSIDE$
ip address 192.168.7.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Dialer1
no ip address
interface Dialer2
description $FW_OUTSIDE$
ip address negotiated
ip mtu 1452
ip nat outside
zone-member security out
encapsulation ppp
dialer pool 1
dialer-group 3
ppp authentication chap pap callin
ppp chap hostname o2
ppp chap password 0 o2
ppp pap sent-username o2 password 0 o2
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat source list 101 interface Dialer2 overload
ip nat inside source static tcp 192.168.7.39 3500 interface Dialer2 3500
ip nat inside source list 101 interface Dialer2 overload
ip nat inside source route-map MAP_ACL interface Dialer2 overload
ip route 0.0.0.0 0.0.0.0 Dialer2 permanent
ip route 192.168.2.0 255.255.255.0 192.168.7.3 permanent
ip access-list extended NAT_ACL
deny ip 192.168.0.0 0.0.0.255 192.168.0.0 0.0.255.255
permit ip 192.168.0.0 0.0.0.255 any
ip access-list extended SDM_BOOTPC
remark CCP_ACL Category=0
permit udp any any eq bootpc
ip access-list extended SDM_GRE
remark CCP_ACL Category=1
permit gre any any
ip access-list extended SDM_HTTPS
permit tcp any any eq 443
ip access-list extended SDM_SHELL
permit tcp any any eq cmd
ip access-list extended SDM_SSH
permit tcp any any eq 22
ip access-list extended all
remark CCP_ACL Category=128
permit ip any any
ip access-list extended all1
permit ip any any
access-list 2 remark CCP_ACL Category=2
access-list 2 permit 192.168.7.0 0.0.0.255
access-list 101 remark CCP_ACL Category=128
access-list 101 permit ip any any
access-list 101 permit udp any any eq domain
access-list 101 permit udp any eq domain any
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
dialer-list 3 protocol ip permit
mac-address-table aging-time 15
route-map MAP_ACL permit 10
line con 0
no modem enable
line aux 0
line vty 0 4
exec-timeout 40 0
password xxxxxxx
transport input telnet ssh
transport output telnet ssh
scheduler allocate 60000 1000
end
