Serial Number : xxxxxxxx | Firmware version : 1.3.12.6-tm (May 28 2008 17:52:01) |
CPU : Intel IXP425-266 | DRAM : 32M | Flash : 8M |
I am using RV042 10/100 4-port VPN Router .
Details Network :
Starhub Fibre Router 192.168.1.1 ( Lan Router IP )
Subnet : 255.255.255.0
DHCP Enable.
RV042 : Load balance enable
Router Lan IP address : 192.168.1.100
DHCP : Disable
Mode : Gateway
I am unable to get any internet IP address for such configurations as below. It will only work with RV042 if I had change my RV042 Lan IP address to 192.168.2.x. Why the RV042 cannot have the same IP Subnet segment the same with 192.168.1.x whereby RV042 had disable DHCP and I had IP printer services in which is required to be at 192.168.1.x
Attachment of my network blueprint .
