Anyone know of Freeware NETWORK Drawing applications?
Endorsed Question
Mar 6th, 2015
I'm looking for freeware network drawing application. Can anyone recommend one?
I like Visio but not in budget right now.
thanks,
Anthony
Cisco Endorsed by Ryan Bowman
Garrett Smith about 2 years 5 months ago
Anthony,
In the list below, I have placed links for free diagramming applications. As mentioned in other responses, Dia is certainly a useful tool, but there are other options available as well.
1.     Network Notepad (http://www.networknotepad.com/index.shtml)
2.     Cade (http://www.weresc.com/cade.php)
3.     Dia (https://wiki.gnome.org/Apps/Dia/Download)
I hope this helps you, and gives you a good idea of some of the tools that are available for working on a budget!
Garrett
*Please note that I cannot vouch for the integrity of these links. These are all freeware sites, so you do run the risk of introducing viruses and spyware to your system. Please use caution.
Overall Rating: 5 (2 ratings)
Boyan Sotirov Sat, 03/07/2015 - 00:30
I also use DIA. It's very light, has an intuitive UI and usually has everything that I need.
Garrett Smith Mon, 03/09/2015 - 08:34
  • Cisco Employee,
Anthony,
Garrett
