03-08-2015 04:15 AM - edited 03-07-2019 10:59 PM
I would like to configure multiple isolated Vlans on the same private (primary) vlan. Is this possible ?
I currently have one isolated and 2-4 communities but was wondering if each of web servers can be placed in its own isolated vlan ?
i am using a cisco 3750 switch.
03-08-2015 06:23 AM
Yes, you can have lots of isolated ports.
Aaron
03-08-2015 12:06 PM
Different isolated vlan ids on same primary vlan 100 ? I have tried and I get an error ?
I want to add 5,6,7 isolated Vlans to primary 100 vlan but mapping fails.
03-08-2015 01:19 PM
Use the same isolated VLAN. The ports configured in an isolated VLAN will be isolated from each other, and from the other VLANs as normal.
03-08-2015 02:54 PM
Thanks for both your inputs.
I am using trunk port to vmware ESXi , I guess I need to create separate trunk ports and vds on vsphere ?
is there any guidelines I can follow?
