03-08-2015 04:26 PM - edited 03-07-2019 11:00 PM
I have been playing around with the "memory free low-watermark" command. However, the amount of free memory reported by this feature is not consistent with the output from the "show processes memory" command. See below.
switch#show proc mem
Processor Pool Total: 71050216 Used: 31824332 Free: 39225884
I/O Pool Total: 12582912 Used: 8673532 Free: 3909380
Driver te Pool Total: 1048576 Used: 40 Free: 1048536
switch#conf t
Enter configuration commands, one per line. End with CNTL/Z.
switch(config)#memory free low-watermark processor ?
<1-4294967295> low water mark of memory in KB
switch(config)#memory free low-watermark processor 10000
switch(config)#
000933: Mar 6 2015 10:40:32.486 nzdt: %SYS-4-FREEMEMLOW: Free Memory has dropped below low watermark
Pool: Processor Free: 5686000 Threshold: 10240000
switch(config)#end
switch#show ver
Switch Ports Model SW Version SW Image
* 1 24 WS-C3750G-24T 12.2(55)SE9 C3750-IPBASEK9-M
2 24 WS-C3750G-24T 12.2(55)SE9 C3750-IPBASEK9-M
I also have the same behaviour on a WS-C2960S-24TS-L
Does anyone know why these memory free values are different?
03-15-2015 10:38 AM
Hi Tom,
Are you immediately seeing it after configuring it?
Or is it occassionaly reporting it?
M
03-15-2015 12:54 PM
Hi Madhukrishnan,
This occurs instantly after entering the command "memory free low-watermark processor 10000".
Tom
