Change TMS SQL usage Port
soohyung choi
We use TMS version 14.6
I need change default ports used by SQL server (destination ports TCP 1433 ->TCP 3341)
Please find sheet or give advise
Thank you
2 Accepted Solutions
Wayne DeNardi
If you run the TMS Tools application (C:\Program Files (x86)\TANDBERG\TMS\TMSTools\TMSTools.exe) and go to the Configuration Tab, that lets you change the Port from the detault 1433.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
You should be able to change the port by adding it to the end of the server\instance address using a comma (,).
Example:  server\instance,port
5 Replies 5
Wayne DeNardi
Wayne
Wayne
I can't find config tab for changing port..
need more help
My earlier reply was for TMS 14.6, from your screenshot you're running TMS 14.3.2.  I am not in front of a device that I can check easily on at the moment, but in your case, you may see the setting once you click on TMS Database Connection Settings.
The latest version of TMS is version 15.0, so you may wish to consider upgrading.
Wayne
Wayne
Thanks reply!
I cheak TMS Database Connection Settings
but don't find the port setting tap..
TMS and SQL was installed same windows server..is it no matter?
