03-14-2015 08:51 PM
Per the Cisco manuals, this proprietary MIB is supported on ONS 9.x release: http://www.cisco.com/c/en/us/td/docs/optical/15000r9_0/dwdm/reference/guide/454d90_ref/454d90_snmp.html#wp48340 -- However, I've tried a combination of 9.1, 9.2, 9.4, 9.6.x systems, both Transponder, TCC, and mixed WSS M6/M12 shelves, and table CISCO-OPTICAL-MONITOR-MIB::cOpticalMonTable always has zero entries.
My goal is to graph historical optical light levels historically on a RRDTool based system such as Cacti or MRTG (Both on Trunk and Transponder Cards).
11-24-2015 06:52 AM
While not SNMP, you can try this if you havent found anything yet.
Open a web browser and go to:
http://x.x.x.x/pm/15m/0
Where x.x.x.x is the IP of your node.
(Login if you have to)
You should see the performance metrics pull in a close approximation to:
LINEWL-1-2-3-RX-1543.73,och,9208,448,448,448,T,T,T LINEWL-1-2-3-RX-1558.98,och,9246,461,461,462,T,T,T LINEWL-1-2-3-RX-1560.61,och,9250,443,443,444,T,T,T LINEWL-1-2-3-TX-1531.12,och,9349,400,401,402,T,T,T LINEWL-1-2-3-TX-1532.68,och,9353,402,402,403,T,T,T LINEWL-1-2-3-TX-1533.47,och,9355,402,403,404,T,T,T
In CSV order:
Interface Name as Shelf-Slot-LINE-Lambda,type,Index,MIN,AVG,MAX
Now the MIN, AVG and MAX are calculated as follows: (n-500)/10
So in this case, TX for 1532.68 has a MIN value of: (402-500)/10 = -9.8dBm
Use cURL for retrieval and Python/Perl/Ruby for parsing and insertion into EMS (We used Zabbix) and you should be well on your way.
07-14-2016 09:54 PM
Adam,
I was working on this with a colleague, and he had to use:
instead.
But it works.
Also http://x.x.x.x/pm generates a bunch of data.
How did you discover this? Have you found other data that's accessible via http?
