03-16-2015 05:38 AM - edited 03-17-2019 02:20 AM
Hi ,
We have got a CUCM cluster [one PUB and One SUB] running on version 7.1.5
We have build CUCM version 10 in offline and now trying to migrate phones data using BAT and getting error message:
Error : 407 The Model type for the specified Product type was not found. To overcome this, we selected Bulk Administration---Phones ---Insert Phones Specific Details .Under this , we need to have Phone Template Name . We created phone template name for 9951 SIP.
After we did this and click on Submit, we are getting another error in logs as below
Line number 1 is not configured for Line on the template
Please advise what could be the issue.
regds,
aman
03-16-2015 06:27 AM
Hi Aman
The Error "Line number 1 is not configured for Line on the template" means you have not configured a DN on Line1 for Template for the 9951 phones.
You need to configure a Dummy DN for the lines on the Template as well.
Aditya Gupta
03-16-2015 08:53 AM
Hi Aditya,
thanks for the reply[+5]
You mean to say I need to configure Dummy DN for each Template which I create for IP phone model .I have 4 IP phone models [6921/9951/7911/7942]deployed in setup.
Please advise.
regds,
aman
03-16-2015 08:56 AM
Hi Chris,
[+5]
I did not opt for PCD since in new setup we need to change DN of existing phones so that I downloaded the BAT for CUCM 10 and was exporting data from CUCM 7.
regds,
aman
03-16-2015 10:43 AM
Hi Aman
If you are importing the phones which have directory numbers, you will need to assign dummy DN, otherwise CUCM will not allow you to import the Phone since it would not recognize the DN field in the import file.
I would suggest, test with few phones of each model first and then do complete import.
Aditya Gupta
03-17-2015 05:37 AM
Hi Aditya,
we could not get the option for entering DN but got the option for LineTemplateName under Phone Template.We created a Phone template and configured LineTemplate.
we configured a name like 6921LINE for 6921 model and were able to insert phones successfully.
thanks for the support.
regds,
aman
03-16-2015 06:58 AM
What process are you using as it is not supported and does not work to use BAT files from one version to another. Have you looked at using PCD for your migration?
