03-18-2015 05:38 AM
Prime-IDRBT/admin# show application status NCS
Health Monitor Server is starting.
Ftp Server is running
Database server is running
Tftp Server is running
Matlab Server is running
NMS Server is stopped.
CNS Gateway with port 11011 is down
CNS Gateway SSL with port 11012 is down
CNS Gateway with port 11013 is down
CNS Gateway SSL with port 11014 is down
Plug and Play Gateway Broker with port 61617 is down
Plug and Play Gateway config, image and resource are down on https
Plug and Play Gateway is stopped.
SAM Daemon is not running ...
DA Daemon is not running ...
Syslog Daemon is not running ...
kindly help
03-18-2015 06:45 AM
have you tried:
#ncs stop
#ncs start
and see if NMS Server restarts
03-21-2015 01:47 AM
Your GUI is inaccessible coz NCS appliance is essentially down leaving couple of process/services up.
First thing you want try it manually restart it, with
ncs stop
ncs start
& if it's not then provide me with the following logs under /optCSCOlumos/logs :
ALL nms_launchout
nms_launchout_startup
nms_sys_error
- Ashok
Please rate the post or mark as correct answer as it will help others looking for similar information
02-20-2023 04:40 AM
what was the resolution
