03-18-2015 07:25 AM - edited 07-05-2021 02:44 AM
I'm trying to find out if any of LTE versions of C819 can work in Mexico.
I don't need LTE connectivity, 3G is sufficient. I only need to use 4G HW version because of build in external antennas in a vehicle.
Any idea?
Thanks.
Karel
03-19-2015 12:43 PM
Karel check the following link .
http://www.cisco.com/c/en/us/products/collateral/routers/819-integrated-services-router-isr/data_sheet_c78-678459.html
http://www.datavis.com/cgi-bin/shippingcalculator.cgi
03-19-2015 01:47 PM
Unfortunately, I'm afraid to trust only data sheets so I'm looking for some tested deployment.
From wiki http://en.wikipedia.org/wiki/List_of_mobile_network_operators_of_the_Americas#Mexico it looks like these bands are used:
850/1900 MHz UMTS, HSDPA, HSPA+
1700 MHz LTE
So the "A" model should work with 3G networks:
C819HG-4G-A-K9 and C819G-4G-A-K9: Multimode LTE for AT&T (700MHz band 17 and band 4); multimode C819 is backward-compatible with Universal Mobile Telecommunications Service (UMTS), high-speed packet access plus (HSPA+): 850, 1900, and 2100 MHz
It looks like LTE band will not be compatible, so I cannot use LTE in the future.
Am I right?
Thanks.
Karel
