03-19-2015 01:15 AM - edited 03-07-2019 11:09 PM
We have a 2960 48 port switch in a remote office with a couple of VLANs (VOIP & Data). The L3 routing is provided via the WAN router and acts as a 'router on a stick' and provides DHCP for both VLANs.
I need to enable DHCP snooping and I have issued the 'ip dhcp snooping trust' on the router port but not for the access ports. I have then added 'ip dhcp snooping' to the switch but not 'ip dhcp snooping vlan x , x' as I was hoping the ip dhcp snooping bindings database would start to fill up after a few days but it hasn't.
If I add 'ip dhcp snooping vlan x , x' I think the users will get issues as there is no database, what should I do as the router is doing the DHCP.
03-19-2015 02:28 AM
You need to identify the vlans where snooping should be implemented using:
ip dhcp snooping vlan #
The default allows dhcp requests on untrusted ports.
03-19-2015 03:20 AM
That's my question, if I enable it on the vlans and the database isn't populating, what will happen?
03-19-2015 04:02 AM
DHCP snooping keeps track of the bindings but you first have to identify what vlans need tracking.
03-19-2015 04:18 AM
Thanks, but what will happen if I enable this and the database isn't populated yet?
