03-19-2015 07:57 PM - edited 03-07-2019 11:10 PM
Hello
Im new to Cisco but i have a client with a switch that was setup a while back. This switch has configuration for a vlan which is being used to supply a cisco access point. This client also has a remote location. The remote location is connected via a local loop from the ISP, and the client would like the same vlan availible to supply an additional cisco access point at the remote site. can anyone assist me?
03-19-2015 10:17 PM
Hey,
Can you clarify your requirement? Do you want to deploy a new AP in the same VLAN?
CF
03-20-2015 05:58 AM
Yes Cisco Freak a new access point at a remote location.
03-20-2015 06:13 AM
Can you clarify the actual connection between the two sites.
Is it a L2 connection or a L3 routed connection ie. how are the sites connected, what devices are at either end etc.
Jon
03-20-2015 06:32 AM
On both ends there are cisco catalyst switches 2900 i believe. the sites are connected via a routed local loop from the isp.
03-20-2015 06:39 AM
Do you currently have vlans that are in both sites ?
And do you have any devices in each site for routing between vlans.
Basically I need to understand whether the link is a L2 link in which case you may well be able to extend a vlan or a L3 link where it becomes a lot harder depending on the equipment you have.
So can you draw a very quick diagram (nothing fancy), to show the network devices in each site and also post the switchport configuration from each 2900 switch used to connect to the link.
Jon
