03-20-2015 02:33 AM - edited 03-11-2019 10:40 PM
we have implemented ASA Cluster consisted of two ASA 5585 9.2.(3) devices and have eigrp turned on outside interface.
The syslog and asdm are constantly filled with the message that eigrp is dropped from the members ip's:
7 | Mar 20 2015 | 08:22:23 | 10.x.y.7 | 224.0.0.10 | EIGRP request discarded from 10.x.y.7 to outside:224.0.0.10 |
3 | Mar 20 2015 | 08:22:23 | 10.x.y.7 | 224.0.0.10 | Deny inbound protocol 88 src outside:10.x.y.7 dst identity:224.0.0.10 |
Seems like the ASA is dropping eigrp packets from the members, but he ASA should be smart enough not to log this messages.
Is there any way to disable this messages filling my syslog beside implementing logging filter?
Borut
Solved! Go to Solution.
03-20-2015 10:47 AM
Is you EIGRP working?
About your request to disable the message........... You can disable the logging message under syslog setup in ASDM
See attached JPG
03-20-2015 10:47 AM
03-23-2015 12:07 AM
I know how to disable a particular message, but that is not the right way to correct this, the messages will show up in other logging destinations.
The point is that the ASA Cluster should be aware of the members and should not treat dropped packets as errors.
And yes our EIGRP is fully functional.
03-30-2015 06:42 AM
I have clicked "Correct answer by mistake", it is not the solution I was looking for.
Is there a way to discard my action and keep this discussion open?
06-18-2019 05:39 AM
I have the same problem, did you solved it already? If yes, can you send me how, pls?
I have 4 context and EIGRP working in 2 ones of them but in 3rd I have the same error massage.
Thanks a lot
Pavol
