03-22-2015 05:38 AM - edited 03-11-2019 10:40 PM
Said release notes are missing from the download page.
Anyone know where to find them?
Marki
Solved! Go to Solution.
03-24-2015 09:47 AM
I agree.. Please open a TAC and we would be able to provide the release notes for this code.
Thanks and Regards,
Vibhor Amrodia
03-24-2015 04:22 AM
This is a new process which we would be following. If you click on the Bug Toolkit and select the required version for which you want detail , it will show you all the related defects that have been fixed.
Thanks and Regards,
Vibhor Amrodia
03-24-2015 06:10 AM
Hmm, how would you formulate the query in Bug Toolkit to target a specific interim release? The only tag I could find was "9.0.4 Interim"
03-24-2015 09:47 AM
Thanks and Regards,
Vibhor Amrodia
03-24-2015 09:56 AM
It's really a step backward that I have to open a call with Cisco (in this case, through our distributor) each time there is a new interim release in order to obtain the release notes which were very easily obtainable via a static page previously.
06-09-2015 09:14 AM
BTW I was indeed in contact with TAC for some time.
Now the "new system" as they called it has been fixed and release notes are being correctly exported to the website again.
So no, this is not a new process. Maybe there is a new backend with more exports, including a new bug toolkit, but the process for text export right onto the interim download page remained the same.
