CUCM/CUC Prevenative Maintenance
williamesimmons
Looking for any recommendations for preventative maintenance of my Cisco Unified Communications Manager and Cisco Unity Connection.  Things like verifying the backups occur, checking system logs, etc.  I have a general idea, but would like to know what specific things others may be doing.
Manish Gogna
A few things that you can check are:
1. Cisco Unified Reporting - to get details about cluster database , replication , mismatched loads on phones etc
2. Outout of following commands on each server to check for core dumps , ntp/dns/tomcat issues , disk/ram/cpu usage etc
show status
utils core active list
utils diagnose test
3. utils disaster_recovery history backup  - to check for any issues with backups
4. You can use RTMT as well for live monitoring of these servers.
Manish
