03-25-2015 04:23 AM - edited 02-21-2020 05:26 AM
Hello Team,
I have my ASA-5545-X configured in Multi context mode. Got 4 Context running on it.
I want to enable ASDM, so that I can create delete or manage context via ASDM.
How do I configure it. Please suggest.
AK
03-25-2015 06:32 AM
Assuming you have the ASDM image loaded onto the ASA's disk, you need to setup the system context to point to that image and allow management via the appropriate management interface. Something like:
asdm image disk0:/asdm722.bin
http management 0.0.0.0 0.0.0.0
03-25-2015 08:27 PM
Hi Ashwini,
You can refer below link for more information.
http://www.cisco.com/c/en/us/td/docs/security/asa/asa84/asdm64/configuration_guide/asdm_64_config/intro_start.html#wp1317726
Tushar Bangia
Note : Please do rate post if you find it helpful!!
