03-26-2015 08:03 AM
Hi All,
I have a core ASA that is running 8.04 code, IKE v1 only, and does not have any group policies for each individual L2L IPSec tunnel defined, or applied under the tunnel-groups. However, many of my branch ASA's are ASA code 9+. When I create a tunnel on a 9+ code branch ASA in ASDM to the core ASA, the ASA auto-configures a group-policy and applies it to the tunnel-group as a general attribute.
My question: If my core ASA does not have any group-policies defined or applied to any of the tunnel-groups, then is the group policy that is auto created & applied on the 9+ code branch ASA for this tunnel required? Or is it moot since the other end has nothing configured/applied? If it is moot, then I want to clean up the ASA configs by removing the group-policies but I want to make sure that is safe first.
Example:
Branch: 9+ Code ASA:
group-policy GroupPolicy_50.xxx.xx.190 internal
group-policy GroupPolicy_50.xxx.xx.190 attributes
vpn-tunnel-protocol ikev1
tunnel-group 50.xxx.xx.190 type ipsec-l2l
tunnel-group 50.xxx.xx.190 general-attributes
default-group-policy GroupPolicy_50.xxx.xx.190
tunnel-group 50.xxx.xx.190 ipsec-attributes
ikev1 pre-shared-key *****
Core: 8.04 Code ASA:
tunnel-group 12.xxx.xxx.178 type ipsec-l2l
tunnel-group 12.xxx.xxx.178 ipsec-attributes
pre-shared-key *
Solved! Go to Solution.
03-29-2015 01:54 PM
You are required to have a group-policy for site to site and RA VPN for that matter. However, if you do not define a group-policy, the tunnel will default to the default group-policy.
Please remember to select a correct answer and rate helpful posts
03-28-2015 07:35 PM
Hello Dean,
You don't need a group-policy assign to a tunnel-group to establish L2L IPSec tunnel, regardless of version differences.
Only reason you would require a group-policy for L2L IPsec tunnel, is to control port-base traffic which can traverse into the tunnel, as you know in the crypto-acl and nat-exemption acl will not accept any port defined ip addresses and it must be ip to ip traffic only.
Hope that answer your question.
Rizwan Rafeek.
03-29-2015 01:54 PM
