03-26-2015 10:30 AM - edited 03-07-2019 11:16 PM
hi,
i was trying to connect PC-SWITCH-ROUTER
On switch Fa0/1(where switch is connected) LED(link) is ON,while On switch Fa0/0(where cisco 2600xl router is connected) LED is not blinking
But when i remove cisco 2600xl router and replaced with cisco 831 router then fa0/0 LED is ON.
i do not know what to do??
please help me to solve this issue
Solved! Go to Solution.
03-27-2015 07:00 AM
When you get a minute;
On the switch do a
show run interface fastethernet 0/2
on the router do a
show run interface ethernet 0/0
and paste the output, please.
Are you using a straight through cable between the switch and router?
Are both sides auto negotiating speed and duplex?
In order for the switch and router to auto-mdix, auto-negotiation needs to be enabled on both sides.
03-26-2015 11:35 AM
Hello rythem007,
Has the port been configured and turned up(no shut) on the 2600xl router?
What is the status of the port when you do a show ip int brief and or show interface on the 2600xl?
If problem still exists, can you do a show run interface x0/0 on the switch and 2600 router and copy it and post it here on the forum?
03-26-2015 07:46 PM
Here i have connected PC to cisco 3500xl(fa0/1 port)
Cisco 3500xl(fa0/2 port) to router 2600xl(ethernet0/0 port)
for cisco switch 3500xl
Interface IP-Address OK? Method Status Prot ocol
VLAN1 unassigned NO unset up up
FastEthernet0/1 unassigned YES unset up up
FastEthernet0/2 unassigned YES unset down down
FastEthernet0/3 unassigned YES unset down down
FastEthernet0/4 unassigned YES unset down down
FastEthernet0/5 unassigned YES unset down down
FastEthernet0/6 unassigned YES unset down down
FastEthernet0/7 unassigned YES unset down down
FastEthernet0/8 unassigned YES unset down down
FastEthernet0/9 unassigned YES unset down down
FastEthernet0/10 unassigned YES unset down down
FastEthernet0/11 unassigned YES unset down down
FastEthernet0/12 unassigned YES unset down down
FastEthernet0/13 unassigned YES unset down down
FastEthernet0/14 unassigned YES unset down down
FastEthernet0/15 unassigned YES unset down down
FastEthernet0/16 unassigned YES unset down down
FastEthernet0/17 unassigned YES unset down down
FastEthernet0/18 unassigned YES unset down down
FastEthernet0/19 unassigned YES unset down down
FastEthernet0/20 unassigned YES unset down down
FastEthernet0/21 unassigned YES unset down down
FastEthernet0/22 unassigned YES unset down down
FastEthernet0/23 unassigned YES unset down down
FastEthernet0/24 unassigned YES unset down down
GigabitEthernet0/1 unassigned YES unset down down
GigabitEthernet0/2 unassigned YES unset down down
Switch#sh
Switch#show vl
Switch#show vlan
VLAN Name Status Ports
1 default active Fa0/1, Fa0/2, Fa0/3, Fa0/4,
Fa0/5, Fa0/6, Fa0/7, Fa0/8,
Fa0/9, Fa0/10, Fa0/11, Fa0/12,
Fa0/13, Fa0/14, Fa0/15, Fa0/16,
Fa0/17, Fa0/18, Fa0/19, Fa0/20,
Fa0/21, Fa0/22, Fa0/23, Fa0/24,
Gi0/1, Gi0/2
1002 fddi-default active
1003 token-ring-default active
1004 fddinet-default active
1005 trnet-default active
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 1002 1003
1002 fddi 101002 1500 - - - - - 1 1003
1003 tr 101003 1500 1005 0 - - srb 1 1002
1004 fdnet 101004 1500 - - 1 ibm - 0 0
1005 trnet 101005 1500 - - 1 ibm - 0 0
now for cisco router 2600xl,
Router#show ip interface brief
Ethernet0/0 192.168.1.1 YES NVRAM up down
Ethernet0/0.2 192.168.2.2 YES NVRAM up down
Ethernet0/0.3 192.168.3.3 YES NVRAM up down
Serial0/0 unassigned YES NVRAM administratively down down
Ethernet0/1 unassigned YES NVRAM administratively down down
thank for reply
03-27-2015 07:00 AM
On the switch do a
on the router do a
03-27-2015 10:02 AM
Switch#show interfaces fastEthernet0/2
FastEthernet0/2 is down, line protocol is down
Hardware is Fast Ethernet, address is 0009.43d6.0d82 (bia 0009.43d6.0d82)
MTU 1500 bytes, BW 0 Kbit, DLY 100 usec,
Keepalive not set
Auto-duplex , Auto Speed , 100BaseTX/FX
Last input never, output 00:04:34, output hang never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
1 packets input, 64 bytes
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 0 multicast
6 packets output, 802 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 lost carrier, 0 no carrier
Router#show interfaces ethernet0/0
Ethernet0/0 is up, line protocol is down
Hardware is AmdP2, address is 0030.9491.2ac0 (bia 0030.9491.2ac0)
Internet address is 192.168.1.1/24
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
reliability 237/255, txload 1/255, rxload 1/255
Keepalive set (10 sec)
Last input never, output 00:00:07, output hang never
Output queue :0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
10 packets output, 851 bytes, 0 underruns
10 output errors, 0 collisions, 1 interface resets
10 lost carrier, 0 no carrier
thanks for reply
08-22-2015 10:24 PM
i was using crossover cable so that was problem
