The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally. New Here? Click here to learn more and get started.
Cisco Community is an active and collaborative place to learn more about our products and ask questions of peers and Cisco experts! Check out some of the most popular conversations happening right now!
Hi Experts,I am sitting with an unique issue where my Auto Attendant works perfectly from inside the office, however it is not reachable from external calls.Connection ISP > SIP > CUBE > SIP > CUCMWhat I am seeing is as soon as I direct the call to C...
Talk to someone on 헔헹헮혀헸헮 헔헶헿헹헶헻헲 smoothly, give their dedicated support line a ring at +[ퟭ-ퟴퟬퟰ-ퟴퟴퟲ-ퟬퟴퟴퟲ]. Take your time and listen carefully to the automated prompts, then share all the required information to help them solve your problem quickly. ...
Hi all, is there any restriction when I integrate Firepower 8350 with FMCv300 AWS Machine Image? the FMCv300 firmware version is 7.4.1-172, but the Firepower firmware version is 6.x. Additionally, If I wanna configure HA between FMCv300, is it possib...
Dear Sir i am new to 8851 ip phone , just need help for speed dial kem i do program speed dial entries into the device and when the phone is turned off the entries are lost is there is any advice why list is forgotten from the phone ? thanks
Hi Team,Our Router having many ikev2 proposal, as per TAC suggestion we need to combine in to single policy. Please let me know for this activity any down time needed ?
Can someone tell me how do I do routing here ? it does not matter if it is static or dynamic I just want to ping same vlans and also I dont want to have different vlans to be pinged
Hi Guys, i had this problem for 8 hours now and can't seem to get it cracked... after i input the command copy xmodem: flash:c2960-lanbasek9-mz.152-7.e9.binand using the SecureCRT going to Transfer > send xmodem I get this and after that nothing happ...
hi i am trying to cable up trhe ucs 6454. I got 2 40G mopdules on port 53 and 54 on each fabric. I got 2 core switches to connect therm to FABRIC 1port 53 ----> port 1 on Core switch APort 54 -----> port 1 on Core Switch BFABRIC 2port 53 ------> port...
Hi, We´ve been using XRd as a way to do integration testing with our autoprovisioning platform using gnmi.This works great.However I'm currently trying to do end to end testing of the whole solution with actual traffic forwarding across the finished ...
want to move the vpc heartbeat connection of a N9K pair from a L2 switch to a direct cable.To my understanding -as long as the peer link is up- a disruption of the heartbeat link should not affect any traffic to the connected hosts.Is this correct? O...
I configured NAT and DHCP relay in GNS3, and all hosts have end-to-end reachability, I can ping PC44 from PC11 and PC22, and also from PC33 if I configure a static IP address.On the NAT router (R11), I also configured DHCP relay with 'helper-address'...
Hi all. Cisco ISE Posture Windows Patch Management Definition update not working properly. Cisco ISE version 3.2 patch 5. Client Agent : Cisco Secure Client 5.1.2 42 Windows client 11 23H2 and Windows Update version is 1023.x. Comliance Module : ...
