VPN
Cisco CyberSecurity
Labels
Hello Experts!I'm setting up a new vpn tunnel to a partner.  ASA on our side Palo Alto on theirs.  When the tunnel connects, it seems to run fine.  However, should the tunnel go down, it will not come back up unless they initiate the traffic.  They c...
irbk by Level 1
  • 1825 Views
  • 54 replies
When the command route inside 0 0 <ip-of-next-hop> tunneled is configured on the VPN ASA, when a packet from a remote user VPN is received, is the local route table consulted for possible destinations before using the tunnel option? Thanks Frank
fsebera by Level 4
  • 5713 Views
  • 9 replies
Dear Friends,I'm configuring site-to-site VPN with Cisco ISR 4331. I have faced two issues.One Phase 1, I can see where to configure the lifetime. Second. When initiate traffic I can see incoming traffic is increasing, but outgoing is zero see below ...
dissai by Level 1
  • 429 Views
  • 18 replies
Having a strange issue when I try and add a client image I receive the following error."Error during file upload. Please ensure that the Firewall Management Center has enough space, the file is valid and that the file name contains only letters, digi...
00u18jg7x27DHjRMh5d7_0-1704726038444.png 00u18jg7x27DHjRMh5d7_1-1704726057225.png
Hello everybody,our customer has a FirePower 2130 running ASA-OS 9.14(2)18 with hundretsof S2S-tunnels.A tunnel (peer 87.129.194.226) is frequently hanging so that only the remotefirewall admin can reset the tunnel to make it transfering fraffic agai...
swscco001 by Level 1
  • 135 Views
  • 2 replies
im trying to do a route based vpn between cisco ASAv and FortigateVM(before production) but on the asa im getting this: #pkts not compressed: 21, #pkts comp failed: 0, #pkts decomp failed: 0 and trasffic only flows from Fortigate to the ASA. commands...
In my collage project i choose provide security to campus network an i want to build IPsec vpn in this project so i need all information about IPsec, I have basic information about IPsec. and if there are any other suggestion regarding this project t...
Dear all,I have an issue related to AnyConnect VPN, & looking forward to the troubleshoot steps.>Some users experience the following error, and this happens frequently >I looked at the user log, this happened because our VPN server (ASA) terminated t...
