ACS 5.X - GUI Login Issue
nomykhan
I have installed ACS 5.1 on vmware fusion.
I am successfully able to login via CLI - created more admin users as well.
When i try to use the same credentials over the web - it fails . Any clue why this is happening?
You might have more luck asking this in the AAA forum
https://supportforums.cisco.com/community/5936/aaa-identity-and-nac
Please remember to select a correct answer and rate helpful posts
Tushar Bangia
The default username for Cisco ACS 5.x n above is 'acsadmin', you must have set one when setting up ACS however if you dont remember than you can reset it as below:
ACS/admin# acs reset-password
This command resets the 'ACSAdmin' password to its original value.
Are you sure you want to continue?  (yes/no) yes
Password was reset successfully
Tushar Bangia
Note - Please do rate post if you find it helpful!!!!
and the default password for the Cisco ACS GUI is 'default'.
Hence post password reset if you try to login via GUI, it will ask you to setup a new password.
Tushar Bangia
