03-28-2015
01:57 PM
- last edited on
02-21-2020
11:55 PM
by
cc_security_adm
Does Cisco VPN client (the legacy IPSEC client) support double authentication with RSA token AND active directory credentials ??
I know that AnyConnect supports this , and the command "secondary-authentication-server-group" is only for ssl connections , but need further confirmation .
Kind Regards
Mohammad
Solved! Go to Solution.
03-30-2015 04:53 AM
Hi Mohammad,
Does the Cisco VPN Client support double authentication?
A. No. Double authentication is not supported on the Cisco VPN Client.
You may find further information about the Cisco VPN client here.
As you said the Only client that supports double authentication is the Cisco AnyConnect Secure Mobility Client.
Please proceed to rate and mark as correct this Post!
Let me know if there are further questions on this!
David Castro,
03-30-2015 04:53 AM
Hi Mohammad,
David Castro,
03-30-2015 05:45 AM
Hi Mohammad,
Could you please mark this forum as aswered, click on "Endorse Answer".
David Castro,
