Is it possible to use extended acl for split tunneling on ASA?
David Kleberson
I'm configuring RA IPSEC VPN on ASA and I would like to figure out whether it is possible to use extended acls as a part of split tunneling?
Thank you!
2 Accepted Solutions
Abaji Rawool
Level 3
Level 3
Yes, you can use extended ACL. Refer this example :http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/70917-asa-split-tunnel-vpn-client.html
Abaji.
Even if you use an extended ACL the ASA will "convert" the ACL (I use the convert statement very lightly) to a standard ACL.  The source IP / subnet will be used for split tunneling and the destination will be ignored.  So unless you configure the source IP with the destination network, the extended ACL will not work.
http://www.cisco.com/c/en/us/td/docs/security/asa/asa91/asdm71/vpn/asdm_71_vpn_config/vpn_asdm_setup.html
Please remember to select a correct answer and rate helpful posts
Abaji Rawool
Level 3
Level 3
Abaji.
The first question that comes to my mind is: Why do you want to do that? Split-tunneling is used for routing-decisions on the client. And on the ASA, that's what standard ACLs are used for. Although you can use an extended ACL for split-tunneling, using a standard ACL is the "native" ASA-way to handle that.
Hi Karsten Iwen,
When you want to use fqdns for your split tunnel ACL, it can't be done using standard but extended. That's a use case.
