Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1929435members
1243901discussions
Community Activity
How Do I Connect With Someone On Klm 𝗔irlines? [#24/7^𝖘𝖚𝖕𝖕𝖔𝖗𝖙]
"How do I get a human at KLM 퐀퐢퐫퐥퐢퐧퐞퐬 immediately? Customer~Service 24*7✔ Passengers Can Call KLM 헔헶헿헹헶헻헲혀 by dialing the (No Wait Time) Phone Number at +1::805-327-7444 (퓤퓚).// +ퟭ::ퟴ05-327-7444 (퓤퓢퓐)} (No Wait Time) or 1-805-KLM(REal Human)/ and get...
jeanna160 by Level 1
  • 1 Views
  • 0 replies
ASR9K:show policy-map interface にて Service Policy not installing となる
はじめに 本ドキュメントでは、ASR9000 シリーズルータにおける、シェーピング機能設定時における制限事項について紹介します。 概要 ASR9000 シリーズルータにおいて、以下のようなシェーピング機能を設定し、"show policy-map interface" にて統計情報を確認しようとした場合に、"Service Policy not installing" と表示され、シェーピングが機能しているログが確認できません。 [設定例] RP/0/RP0/CPU0:ASR9K#show r...
The operation took longer than expected.
I have just synchronized both Active Directory and Cisco ISE, ISE is using my server (AD) as an NTP server, everything is fine, but now I'm facing an issue "Status Summary: The operation took longer than expected. This may be caused by slow network c...
Jason2005 by Level 1
  • 188 Views
  • 9 replies
Resolved! 关于4507的ARP表项无法ping通疑惑??
型号:4507环境:两台4507组了VSS,VLAN 32,SVI地址是192.168.32.254,该VLAN未做其他设置,就设置了SVI。出现的问题:VLAN32的终端设置出现间歇性失联,核心查看ARP表的时候可以看到无法ping通的MAC地址,但是不论是哪个网段的终端都无法PING通该IP,只有当我在核心/二层接入交换机PING该IP后,重置ARP的AGE表项,该异常终端IP就又可以PING通,循环往复。不知道是否是BUG? 配置如下:vlan配置:interface Vlan32ip a...
weihunter by Spotlight
  • 2857 Views
  • 10 replies
funciona no switch CBS250 para comunicação via trunk
Hoje temos um parque completamente formado por switches Cisco Catalyst série 2xxx, 3xxx e um core série 4xxx. Conseguiremos interconexão de um modelo CBS250 com um Catalyst usando trunk? O protocolo VTP irá funcionar?
vvsilva by Level 1
  • 65 Views
  • 2 replies
Cat9200/9200L 製品の Stack 構成において、管理ポートから不正な MAC をもつパケットを送信する場合がある
2024年4月24日 (初版) TAC SR Collection主な問題 Catalyst 9200 / 9200L シリーズの Stack 構成において、Active な管理ポート ( EMP : Ethernet Management Port ) が、Active role の機器上のものではない場合、管理ポートより不適切な MAC アドレスをもつパケットを送信する場合があり、接続先の機器にて不要な MAC アドレスの登録されることがあります。管理ポートからは適切な MAC アドレ...
CUCM 11.5.1 SU2 upgrade
Hello Everyone, one of my clients currently have a CUCM cluster with 1 publisher and 6 subscribers, this cluster is running version 11.5.1 SU2. i am planning a refresh upgrade to version 14 using PCD. but before this upgrade, i am planning a minor up...
Minor edit in one of the OpenTelemetry Blog
Hey!I'm Chitransh, part of the team at SigNoz.Thanks for using SigNoz as one of the Observability backend for OpenTelemetry in this blog -  https://www.thousandeyes.com/blog/data-observability-backend-opentelemetryI just wanted to point out a small c...
chitransh by Level 1
  • 47 Views
  • 0 replies
  • 1 Helpful votes
