03-30-2015 09:35 AM - edited 03-07-2019 11:19 PM
What does the status 'Open' really mean? I read the documentation that says 'the pair of wires is open', which doesn't explain much.
03-30-2015 10:55 AM
Hope the below helps you
https://supportforums.cisco.com/document/74231/how-use-time-domain-reflectometer-tdr
Madhu
04-01-2015 10:49 AM
Hi Robert,
Has the above helped?
Do you require any more help?
Madhu
04-02-2015 12:10 PM
Robert,
Your question is "loaded". I will find it difficult to answer that question if I don't see the output to the command "sh cable tdr interface <BLAH>".
