The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally. New Here? Click here to learn more and get started.
Cisco Community is an active and collaborative place to learn more about our products and ask questions of peers and Cisco experts! Check out some of the most popular conversations happening right now!
Hey everyone, Hope you're all doing great! I'm looking to update my ACI APIC, but I'm a bit lost on where to start. My current version is pretty ancient and it's never been updated. Here's what I've got: Role Pod Node N...
Is there a tool available to convert a Check Point Security Policy to a Cisco Access Control List?The process of doing this manually would be time consuming and could result in human error
Hi, We´ve been using XRd as a way to do integration testing with our autoprovisioning platform using gnmi.This works great.However I'm currently trying to do end to end testing of the whole solution with actual traffic forwarding across the finished ...
HistoryRequirementsConfiguration StepsManaging the KeysChanging the PasswordVerificationThese need to be reviewed \ changed.These are safe to use.FAQReferences History Traditionally Cisco has used several different methods for storing passwords and ...
HelloWe have a lot of clients getting the following error when contacting diffrent sites: ERR_SSL_PROTOCOL_ERROR, we have read that SonicWall and Palo Alto also have these problemes. Solution is to turn off "TLS 1.3 Hybridized Kyber Support" in chro...
Ask Me Anything Event Welcome to the Cisco Community Ask Me Anything conversation. Submit your questions from Wednesday, April 10, 2024 through Wednesday, April 24, 2024. Our Community VIPs, Kathy New and Maren Mahoney will be waiting to assist you ...
Hi ,need some help on this error message.The error was: A built-in element encountered an exception of typecom.sun.jersey.api.client.ClientHandlerException. The root cause was: com.sun.jersey.api.client.ClientHandlerException: java.net.SocketTimeoutE...
Hi All. I would like to get your thoughts on the following issue i have been facing since implementing Dual ISP and failover for site-to-site vpn tunnels.Hub Site:ASA5515 using 9.6(4)42Spoke sites:Cisco ISRs using 15.1(4)M8, using voip services over ...
Hello we have a local 9120axi AP with a 9800LC WLC that seems to be losing connection. The AP is in flex connect, all config looks fine: AdvancedCountry CodeUS Multiple CountriesUSStatistics Timer180CAPWAP MTU1485AP Link LatencyEnabledAP PMK Propaga...
I have 2 Cisco 8811 phones that have been migrated to Webex Calling from CUCM. They have been active and working with Webex Calling for several months. No changes have been made in Control Hub and users have been working normally. Now all of a sudden...
Hello Cisco-Community ! We actually face a severe problem concerning mostly our cellphone or landline call-in users in WebEx meetings or even conversations from PSTN (mostly vodafone mobile) to normal CUCM SIP registered internal office phones. It ra...
I have a real estate office with a receptionist and a realtor. The realtor phone is set for CallFwdAll to their cell phone. The customer calls into the main number. Then transfer the call to the realtor. The call then get's forwarded to the reatlor's...
want to move the vpc heartbeat connection of a N9K pair from a L2 switch to a direct cable.To my understanding -as long as the peer link is up- a disruption of the heartbeat link should not affect any traffic to the connected hosts.Is this correct? O...
Hi Team,Our Router having many ikev2 proposal, as per TAC suggestion we need to combine in to single policy. Please let me know for this activity any down time needed ?
