04-01-2015 07:26 AM - edited 07-05-2021 02:50 AM
i am using one wlc 5760 and layer 2 switch
connectivity i am using trunk connectivity b/w wlc and layer 2 switch.
i want to access the web of WLc 5760
In wLc5760 i had configure
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
ip address 10.1.1.2 255.255.255.0
no ip route-cache
negotiation auto
ip route vrf Mgmt-vrf 0.0.0.0 0.0.0.0 10.1.1.1
interface Vlan 1
ip address 192.168.1.10 255.255.255.0
wireless management interface vlan 1600
Layer 2 switch
vlan 1
ip address 192.168.1.12 255.255.255
then i can access the web of Wlc with ip address 192.168.1.10
or
i need layer3 device for intervlan routing
04-28-2015 01:43 PM
Hello Syed,
Please go through the below link which contains configuration guide.
http://www.cisco.com/c/en/us/td/docs/wireless/technology/5760_deploy/CT5760_Controller_Deployment_Guide/CT5760_Centralized_Configuration_eg.html.
04-28-2015 04:50 PM
As long as you are on 192.168.1.0/24 network you can access 5760 using https://192.1681.10
Since 5760 is L2, your wireless management interface should be same as 5760 management vlan (vlan 1 in this case, not 1600)
If you want to access it from different subnet, then L3 device is required to do the intervlan routing
Rasika
*** Pls rate all useful responses ***
04-29-2015 02:15 AM
Refer the link for CT5760 Controllers Web GUI Deployment Guide
04-29-2015 02:40 AM
