04-01-2015 01:35 PM - edited 03-11-2019 10:43 PM
Dears,
I am looking for anyconnect vpn configuration for smart iphone 6,5s,which will communicate through cisco jabber to the corporate any document from cisco .I want to know the complete setup
thnanks
04-03-2015 07:07 AM
Hi Clark,
It will depend on the VPN server, if the server will be the ASA, you can find the configuration guides here:
- http://www.cisco.com/c/en/us/support/security/anyconnect-vpn-client/products-configuration-examples-list.html
If it is the router:
- http://www.cisco.com/c/en/us/support/docs/routers/3800-series-integrated-services-routers/110608-ssl-ios-00.html
Hopes this helps! If you have any question regarding the configuration, let me know!
Please proceed to rate and mark as correct the helpful Post!
David Castro,
04-29-2015 11:53 AM
Here is the Any connect VPN for iPhone, smart phone configuration guide:
http://www.cisco.com/c/en/us/td/docs/security/vpn_client/anyconnect/anyconnect30/user/guide/iphone-ugac-ios.html
11-29-2019 04:42 AM
I have the same issue, with Cisco Firepower 4120.
Only ASA documentation exists.
