Posturing support on cisco lan lite switch
Dear all,
I come to know that cisco ISE posturing is not supported in cisco catalyst switches with LAN Lite image. Is there any way out to manage it with any agents installed ?
Bikash
nspasov
Hi Bikash-
You will need to upgrade your switches to a min of LAB Base which will not only allow you to do posture but also, central web auth, 802.1x, etc. Lan Lite will not work for ISE deployments as it does not even support basic 802.1x features.
Thank you for rating helpful posts!
