router 2900 & 2800 active standby
MMoharam1
I want the below routers to work as ACTIVE & STANDBY  ,
  • The 2 routers share the same configuration  ( automaticaly )
  • When active is defected shutdown the standby works as active
Existing  router :- cisco2811-v    + VWIC3-1MFT-T1/E1
New added router :-  2911-v   + VWIC3-1MFT-T1/E1
1.0
CISCO2911-V/K9
Cisco 2911 Voice Bundle  PVDM3-16  UC License PAK  FL-CUBE10
PWR-2911-AC
Cisco 2911 AC Power Supply
CAB-ACE
AC Power Cord (Europe) C13 CEE 7 1.5M
HWIC-BLANK
Blank faceplate for HWIC slot on Cisco ISR
ISR-CCP-EXP
Cisco Config Pro Express on Router Flash
MEM-2900-512MB-DEF
512MB DRAM for Cisco 2901-2921 ISR (Default)
MEM-CF-256MB
256MB Compact Flash for Cisco 1900 2900 3900 ISR
SL-29-IPB-K9
IP Base License  for Cisco 2901-2951
SL-29-UC-K9
Unified Communication  License  for Cisco 2901-2951
SM-S-BLANK
Removable faceplate for SM slot on Cisco 290039004400 ISR
FL-CUBEE-5
Unified Border Element Enterprise License - 5 sessions
S29UK9-15403M
Cisco 2901-2921 IOS UNIVERSAL
VWIC3-1MFT-T1/E1
1-Port 3rd Gen Multiflex Trunk Voice/WAN Int. Card - T1/E1
PVDM3-16U64
PVDM3 16-channel to 64-channel factory upgrade
Tinashe Ndhlovu
You can use a First Hop Redundancy Protocol of your choice, HSRP, VRRP or GLBP.. you'll have to research on these because there's so many bells and whistles but pretty easy for a basic set up. The standby takes over when active fails or link goes down or link speed goes below a certain threshold etc there's just tonnes of things you can tweak. You'd need a redundant connection to the outside ISP (I am assuming that's the set up you have in mind).
As for automatically sharing the same configuration, I could be wrong but I am not so sure routers can automatically share changes between each other without admin intervention, maybe u can use CSM to push configs to both routers.
THANKS YOU A LOT
