2851 bad memory block
Infuscomus
I had some strange crashes recently on a 2851.
When checking the crash logs I have found that the crash is due to a Address Error (load or instruction fetch) exception.
The exception happens at the same address every time.
Is there a way to isolate that memory block from active memory / to mark it as unusable so the system will no longer try to read from it ?
Is the memory module on the 2851 replaceable or is soldered into the MB ?
johnlloyd_13
Level 9
Level 9
hi,
no you can't isolate/disable the memory block and refrain the router from using it.
the memory stick is replaceable on its DIMM expansion slot:
http://www.cisco.com/c/en/us/td/docs/routers/access/2800/hardware/installation/guide/hw/10_hw.html#wp1026137
http://www.cisco.com/c/en/us/td/docs/routers/access/2800/hardware/installation/guide/hw/01_hw.html#wp1037629
but before you do that, i would suggest to open a TAC case, if still under contract, to properly diagnose that it's indeed a bad memory/RAM problem.
johnlloyd_13
Level 9
Level 9
hi,
