04-08-2015 06:55 AM - edited 03-19-2019 09:26 AM
one of my customers uses HotDial on a CUCM in conjunction with a VG224 in SCCP Mode.
HotDial is build up on the CUCM with a dedicated CCS which points to a TranslationPattern with the destination.
So far everything works fine.
But if the called destination hangs up before the initiator goes on hook - the CUCM dials the number again and the customer doesn't want this behaviour.
"Normal" IPPhones do not show this behaviour.
Any suggestion what to do?
regards
joerg
04-08-2015 10:50 AM
Hello joerg,
You can try changing the hookflash timer on the vg224 port, if not already configured.
voice-port 2/0
timing hookflash-in 1000
Hope this helps.
05-06-2015 04:09 AM
Hello Charles,
many thanks to you - but this is something we already tested without success.
reagrds
joerg
