Can't access c3550 over network
EasthillMike
Hello!
I'm having trouble getting my c3550 to communicate on my network. I believe that I've set it up correctly, but there's obviously something wrong. I would appreciate any insight you may have. My network is currently 192.168.0.0/22 without VLANs. Here's some device output:
C3550_01#show running-config
Building configuration...
Current configuration : 2595 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname C3550_01
enable secret 5 $1$dwg9$2H2g.v8NcqqLl9lR9axK8.
enable password 123456
ip subnet-zero
spanning-tree mode pvst
interface FastEthernet0/1
 switchport mode dynamic desirable
 no ip address
... (0/2 - 0/23 have identical output)
interface FastEthernet0/24
 no ip address
interface GigabitEthernet0/1
 no ip address
interface GigabitEthernet0/2
 no ip address
interface Vlan1
 ip address 192.168.3.251 255.255.252.0
ip default-gateway 192.168.3.254
ip classless
ip http server
line con 0
 exec-timeout 0 0
line vty 0 4
 password 123456
 login
line vty 5 15
 password 123456
 login
end
C3550_01#show interfaces vlan 1
Vlan1 is up, line protocol is up
  Hardware is EtherSVI, address is 000e.d78f.ca80 (bia 000e.d78f.ca80)
  Internet address is 192.168.3.251/22
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Last input 15:23:05, output never, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 2
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicast)
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 interface resets
C3550_01#show vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/2, Fa0/3, Fa0/4, Fa0/5
                                                Fa0/6, Fa0/7, Fa0/8, Fa0/9
                                                Fa0/10, Fa0/11, Fa0/12, Fa0/13
                                                Fa0/14, Fa0/15, Fa0/16, Fa0/17
                                                Fa0/18, Fa0/19, Fa0/20, Fa0/21
                                                Fa0/22, Fa0/23, Fa0/24, Gi0/1
                                                Gi0/2
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
Remote SPAN VLANs
Primary Secondary Type              Ports
C3550_01#
InayathUlla Sharieff
Few question:
1- From were and how are you trying to access?
2- Are you able to ping this device from that machine/device from which you are trying to access?
3- how are you trying to access( Telnet/ssh) have you enable this on line vty?
Inayath
Thanks for the response!
If I understand your questions correctly,
1 - I'm attempting to access the switch across my network (via wired ethernet) from my admin workstation. The switch does not respond to network discovery attempts, including ping.
2 - I'm unable to ping the switch or any device connected to it from my admin computer. Also, devices connected to the switch can't ping each other, the switch, or any network IP.
3 - The only access I have right now is through the serial console.
I should probably also mention that this switch is being configured on my bench before deployment - if I can get it to work.
