I do think you can change the mode from local to bridge, I don't have on in front of me, but if you have that option, then you can use mesh. The issue is that you will need to pass all the vlans across and that can get tricky. Take a look at this link as it explains it pretty good:
http://phasedcoexistence.blogspot.com/2011/12/cisco-mesh-ethernet-vlan-tagging.html
Setting them up as autonomous might be a bit easier to do though.
-Scott
-Scott
