04-10-2015 02:07 AM - edited 03-05-2019 01:13 AM
Problem: I have an old 2851 with VPN module.
Currently, there are IPSEC crypto-connections in use that go through an EIGRP tunnel.
Showing crypto engine br I get: VPN Module (HW) status enabled.
Showing crypto maps, I see that there are leased some active ones.
Showing aaa: there are active sessions.
According to the documentation here:
The 2951 has embeded IPSec support.
The question is: Is a VPN additional module (3DS/AES encryption module) needed for the 2951 or will the connections work without it ?
Solved! Go to Solution.
04-13-2015 01:15 AM
Hello.
It will work, but requires SEC/K9 license (and general image, not NPE):
Also if you want to do IPSec for traffic rates higher than 85M unidirectional.
04-13-2015 01:15 AM
Hello.
04-14-2015 03:32 AM
Is the same valid for the ISR 4351 series ?
