04-14-2015 11:04 AM
The Sourcefire community is only accessible (as far as I can tell) from within the pages of the Security Community.
Should it not also appear in the sitewide Community Directory flyout menu that appears when you hover?
Also, sub-community threads within Sourcefire don't appear to be rolling up to the Sourcefire community level.
See images below for my first two points:
Solved! Go to Solution.
04-16-2015 08:28 AM
Hi Marvin,
Actually, we require at least 20 contribution posts per week and we also put other business consideration in mind when deciding to add a community to the community directory. This is so the community directory does not get too large.
I think the reason why the Sourcefire content is not showing at Security level is because the content posted is not directly posted to Sourcefire but sub community below it. I believe we only show content of its direct children.
Thank you.
04-14-2015 12:57 PM
Note - the current Directory menu require 1280x1024 display as a minimum to be displayed in full. It's not possible to scroll to bottom on smaller display, so communities on bottom are unreachable from the menu at all even now.
It need's to be taken into consideration.
04-16-2015 08:30 AM
Thanks Dan! I'll log this issue with our user experience team to investigate further.
04-16-2015 08:28 AM
Hi Marvin,
Thank you.
