AIR-AP1131AG-I-K9 support AES 256 bit ?
kfir Ben Zur
hi,
I have several AP devices:
Product/Model Number: AIR-AP1131AG-I-K9
 System Software Filename: c1130-k9w7-tar.124-3g.JA
 System Software Version: 12.4(3g)JA
Bootloader Version: 12.3(8)JEA
i need to know if  AES 256 bit is supported by this devices and if the current software need to upgrade for that.
Sandeep Choudhary
HI Ben,
As per my knowledge this Software dont support 256 bit key size.
Here is the link:http://www.cisco.com/c/en/us/td/docs/wireless/access_point/12-4_3g_JA/configuration/guide/ios1243gjaconfigguide/s43wep.html
another version: 12.3(8)JA supports 256 bit key size to protect data traffic,
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/12-3_8_JA/configuration/guide/1238jasc/s38wep.html
Don't forget to rate helpful posts
