XML API Authentication Fails
alexturner121
Trying to set up the XML API on an ASR 9K and find myself unable to authenticate with the XML API using Netcat.
I've configured the box as below:
Building configuration...
!! IOS XR Configuration 5.1.2
!! Last configuration change at Wed Apr 15 07:19:42 2015 by root
username xml
group sysadmin
secret 5 $1$LY8B$39t3eTXf/ajMGWnX99.ux0
password 7 07182E414C080D1657
aaa authorization exec default group tacacs+ local
interface MgmtEth0/RSP0/CPU0/0
ipv4 address 10.2.100.1 255.255.0.0
interface MgmtEth0/RSP0/CPU0/1
 shutdown
interface TenGigE0/0/2/0
 shutdown
interface TenGigE0/0/2/1
 shutdown
interface TenGigE0/0/2/2
 shutdown
interface TenGigE0/0/2/3
 shutdown
router static
 address-family ipv4 unicast
  0.0.0.0/0 10.2.0.1
ssh server v2
xml agent ssl
xml agent tty
xml agent
iteration on size 100
end
and RP/0/RSP0/CPU0:ios# xml echo Wed Apr 15 07:27:10.765 UTC XML>
I've got two test users, root:root and xml, both of which I can connect to using SSH though the XML interface seems to reject them - using nc:
alexanderturner@Alexanders-MacBook-Pro~/Downloads> nc -v 10.2.100.1 38751
found 0 associations
found 1 connections:
    1:  flags=82<CONNECTED,PREFERRED>
    outif en0
    src 10.0.1.40 port 61066
    dst 10.2.100.1 port 38751
    rank info not available
    TCP aux info available
Connection to 10.2.100.1 port 38751 [tcp/*] succeeded!
User Access Verification
Username: root
Password: root
Is this not authing against local?
Alex
xthuijs
hey alex,
it is likely failing tacacs author because of this line:
as long as the tacacs server is available, it will try against him and if that user doesnt exist in tacacs, it will fail that shell author.
revise config to:
aaa authentication login default local
aaa authorization exec default local
have a local username available that has cisco-support/root-system
or you can also do a debug aaa author and debug tacacs and see what service is requested so taht the user profile can be updated providing that author if you like to leave the existing tacacs author in place.
cheers!
xander
