04-15-2015 02:57 PM - edited 07-05-2021 02:56 AM
I recently upgraded to PI 2.2. Now where the heck do you create a new WLAN? I tried configuration/network devices/wlc/my controller, select controller, then configure, but there is no WLAN. Am I missing a step. I really wish they documented major changes like this when a new version is released.
Thanks for the help!
04-15-2015 11:26 PM
04-16-2015 04:39 AM
Unfortunately Sandeep the Classic Theme has been deprecated.
04-16-2015 08:59 AM
One approach might be to create a WLAN template and apply it to the WLC:
Configuration > Templates > Features and Technologies > Controller > WLANs > WLAN Configuration.
You can find more information in the Prime 2.2 Reference Guide below-
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-2/reference/guide/pi_ref/config_field_ref.html#51983
Pete.
04-16-2015 11:25 AM
Go figure was missing a few radius attributes that prevented me from seeing the Features and Technologies. Maybe you can check this as a correct answer to help the next guy.
From Prime:
Administration/User groups
Click the task list to the right of the group you want to use the attributes of.
Copy these attributes and apply them to your radius server, or tacacs server.
Be sure to include the virtual domain as part of your attributes.
