ACS 5.5 routing between interface
Lorenzo46
My question is simple:
I have an ACS with 3 interfaces: Gi0/0, Gi0/1 and Gi0/2. I've configured the 3 interfaces with 3 different IP Addresses. I've made this because I have 3 networks: Management (10.10.0.0/24), Network 1 (10.10.1.0/24) and Network 2 (10.10.2.0/24). The ACS has configured with ip default gateway on Management Network.
TheACS is the Radius Server for the 3 separated networks.
I'd like to know if the ACS has routing capability or it is able to guarantee the isolation between the network.
For my scope, repeat, I need the isolation between the networks.
Thank you for the support!
Best Regards
Lorenzo
johnd2310
Level 8
Level 8
You need a firewall like the ASA to isolate networks. The ACS is used for authentication and does not do network segregation.
John
**Please rate posts you find helpful**
