04-16-2015 11:53 AM
Good morning,
I need to know I require for activation TWAMP in ASR9010?
Additional got these questions before setting TWAMP:
1. If the ASR 9010 supports UDP Echo Reflector and how to configure.?
2. If you need a specific license?
3. SMU recommended to enable this functionality?
4. The estimated per customer (eNB) BW once active?
5. Additional Recommendations?
Victor Vega
Solved! Go to Solution.
04-23-2015 07:34 AM
hi victor,
you can find more info on TWAMP and how to set it up here:
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r5-1/system_monitoring/configuration/guide/b_sysmon_cg51xasr9k/b_sysmon_cg51xasr9k_chapter_0100.html#concept_BEC89ABFB24E417F9748291182E83A48
no smu's necessary, but minimally you need XR 5.1.1, so 5.1.3 is recommended in that case.
regards!
xander
04-23-2015 07:34 AM
hi victor,
regards!
xander
04-30-2015 08:21 AM
Hi Alexander,
Thank you very much for the information.
Victor Vega
05-11-2015 11:11 AM
Hi Alexander;
And it does not seem to work.
Any help would be greatly appreciated!!!
05-11-2015 11:25 AM
hey victor, hmm... ok we need to do some troubleshooting then, and sicne my crystal bowl just broke, I think I need to see some debugs and a bit more precise details as to what doesn't work or where it goes wrong.
This could be a little tedious via the forums and in that light it may be easier to have a tac case so that one of our engineers can work directly with you to pull the info and reduce the back and forth a bit possibly.
When you decide to file a support case, make sure you include a topo, configs, versions, installed smu's, troubleshooting done, details of the np counters, identification of drops, as we need to find out right now where the paks are getting lost. or in fact see what the precise problem is...
cheers
xander
12-12-2023 01:41 AM
Provided link is not accessible
