04-16-2015 01:52 PM - edited 03-05-2019 01:16 AM
Just attempting to set a simple configuration on this router. I want a static on the WAN FE4 and a dhcp server on the VLAN for the switch ports 0-3.
I can get the DHCP working and ping the cisco from my device but I can not go any further. Originally thought it was a default route issue but after comparing with other logs mine appear to right. They probably aren't, I am new to these routers and have purely worked with mikrotik's for last 10 years. Can anyone point me in the direction on how to fix this?
Here is a test setup I did to replicate the same issue with pings or traffic not passing through the box. You will see I now have the WAN port setup as DHCP to our internal router. I built everything the exact same and figured if you could help me with this one I can rebuild it with my static and good to go. Any help would be greatly appreciated.
Router#show run
Building configuration...
*Apr 16 20:48:13.819: %SYS-5-CONFIG_I: Configured from console by console
Current configuration : 1636 bytes
! Last configuration change at 20:48:13 UTC Thu Apr 16 2015
version 15.3
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
ip dhcp excluded-address 10.10.35.1 10.10.35.10
ip dhcp pool office
network 10.10.35.0 255.255.255.0
default-router 10.10.35.1
dns-server 8.8.8.8 8.8.4.4
lease 3
ip cef
no ipv6 cef
license udi pid C881-K9 sn FGL19042492
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
switchport access vlan 3
no ip address
interface FastEthernet4
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
no cdp enable
interface Vlan1
no ip address
interface Vlan3
ip address 10.10.35.1 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Vlan3 overload
ip route 0.0.0.0 0.0.0.0 FastEthernet4
ip route 0.0.0.0 0.0.0.0 10.10.30.1
access-list 1 permit 10.10.35.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Router#
Solved! Go to Solution.
04-17-2015 02:19 AM
Hi mcnaught02,
You test setup has problems that may or may not translate into your real setup so here goes...
interface FastEthernet0 to FastEthernet2
Set to Vlan 1 Not Vlan 3, Vlan 1 has no IP addressing or DHCP scope
Also Have you created VLAN 3? (show vlan brief or show vlan-switch depending on platform)
Does a client attached to FE2 get an IP address within the 10.10.35.0/24 range?
"ip nat inside source list 1 interface Vlan3 overload"
This may be your actual source of your problem, you probably actually want
"ip nat inside source list 1 interface FastEthernet4 overload"
The difference is which IP address gets used for the Source address in the NAT.
Also "ip route 0.0.0.0 0.0.0.0 FastEthernet4" you should only use interface routing for dedicated point to point interfaces like Frame relay links or Tunnels, Using this config can cause problems especially if there is more than one IP address present in the network attached to Fa4.
I'm assuming that the second route "ip route 0.0.0.0 0.0.0.0 10.10.30.1" is the legitimate one.
Hope that helps.
04-17-2015 02:19 AM
Hi mcnaught02,
Hope that helps.
04-17-2015 12:23 PM
Brendon,
That was just a test setup I was using to identify if the default vlan1 was my problem I was only using Fastethernet 3 to test the connection with VLAN 3 that I created.
I reset the configuration and changed the overload string that you suggested and it did fix the problem. I actually got that command from watching a youtube video so I greatly appreciate your information. All up and working and the phones seem to be really happy with the new router.
Unless you have any recommendations or settings I need to do I think I am fixed.
Have a great weekend!
04-17-2015 11:55 PM
Glad to be of assistance, Securing the router is the other main thing I'd recommend
place an ACL against the vty interfaces, external interface and if necessary internal vlan interface, enable aaa if you have an external auth server, enable ssh, things like that.
04-20-2015 09:25 AM
I have gone back and secured the cisco, no triple aaa or anything like that. Just a simple router to work with the VOIP phones that are running because the old cisco/linksys vpn router wasn't able to handle the traffic and 9 phones on it.
Thanks again!
04-17-2015 01:01 PM
Hi. Your NAT statement is wrong. Please remove this statement by entering
no ip nat inside source list 1 interface Vlan3 overload
Then add this NAT statement
