04-17-2015 04:42 AM
Is this connection model supported? See attached diagram.
08-27-2015 11:50 PM
have you tested?
regards
09-11-2015 08:25 AM
Yes we have. This is working and in production.
10-15-2015 03:47 AM
Hi Colin,
Is it neccesary any special configuration in parent switch N5672 to deploy it?
Best Regards,
Ruben
10-15-2015 04:03 AM
No. Standard fex-fabric port-channel
Colin
10-15-2015 04:08 AM
Thanks a lot Colin.
I suppose that was necesary configure something in the parent switch to advertise the configuration 10G-to-40G port in the FEX switch.
Best Regards,
Ruben
10-15-2015 04:26 AM
Nothing special is required on the N5K. Standard 10G fex-fabric port-channel. The 2300 series 40G FEX will auto recognize the 10G transceiver on the N5K.
Once connected do "show fex 1xx transceiver" and you will see (24) FEX Uplinks available. (4) for each 40G port.
Cool stuff.
Colin
10-15-2015 04:31 AM
Thanks for your support Colin,
Best Regards,
Ruben
09-09-2016 10:45 AM
Hey Ruben,
What FEX 4 x 10 Breakout did you order? May I know the SKU#?
Michael
09-12-2016 12:52 AM
Hi Michael,
We finally use breakout cable from the local provider in spain. because we need a lot of patch cord like breakout.
You can use Cisco cable too via twinax cable (if the distances permit it), this cables are in this web:
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/40GE_Tx_Matrix.html
or "Cisco" Patch cord if you need :
part number H757908QPH-KW010F) : http://www.cisco.com/c/en/us/products/collateral/switches/nexus-6000-series-switches/guide_c07-726164.HTML
I hope have expleined correctly.
Best REgards,
Ruben
09-12-2016 01:19 PM
Thanks Ruben for your detailed information.
I understand that all these breakout cables are supported with 2348UPQ, unfortunately our parent switch is Nexus 5548P, which doesn't support any 10G AOC cables as per the 10G SFP+ compatibility matrix. After having some research and assistance from Support Community, my conclusion is that QSFP-4x10G-AC7M and 10M are only two breakout cables which can be used to connect N2348UPQ 40G port to 10G ports of N5548P.
09-12-2016 11:55 PM
Hi Michael,
Im sorry, we have installed this solution only with N5672 and N23XX. I can tell you that is working correctly without problema and it is very easy to deploy, there isnt additional command to configure it.
If you have $$$$ enough, you can deploy the solutions with 40G FET (MPO/MTP) to 10G FET (LC) and the breakout cable, it is more expensive but it is a more flexible solution.
Best Regards,
Ruben
