04-17-2015 08:50 AM - edited 03-05-2019 01:16 AM
Hi All,
Can you please any one help me in below question.
How many routers can connect back to back .(for example: i have 250 Routers which is connected one to second , second to third , third to fourth etc.
PC-A which is connected to first Router and PC B connected to Last router(250th Router).
Possible to ping from PC-A to PC-B if i am using static route otherwise dynamic protocols like OSPF & EIGRP.
Please reply............
Solved! Go to Solution.
04-17-2015 10:44 AM
Don´t forget maximum TTL is 255, so you can have only 255 hops away, now do the math
04-17-2015 10:44 AM
04-17-2015 10:44 AM
