04-18-2015 09:36 AM
The configuration is like this ....
Dynamic-template configuration:
dynamic-template
type ppp t-adsl
ppp max-failure 5
ppp timeout retry 10
ppp authentication ms-chap pap
ppp timeout authentication 10
ppp max-bad-auth 5
ppp lcp delay 10 0
keepalive 30
ppp ipcp dns 80.191.93.93 4.2.2.4
accounting aaa list default type session periodic-interval 5
ipv4 mtu 1492
ipv4 unnumbered GigabitEthernet0/0/0/1.999
ipv6 enable
and pppoe bba-group configuration:
pppoe bba-group bba_1
service selection disable
sessions mac limit 1
sessions mac throttle 4 30 100
and finally policy-map configuration:
policy-map type control subscriber p-t2
event session-start match-all
class type control subscriber tcq-pppoe do-until-failure
10 activate dynamic-template tcq-adsl
event session-activate match-all
10 authenticate aaa list default
end-policy-map
where is the problem?
04-23-2015 07:41 AM
It looks like your template name doesn't match with what you're activating in the control policy:
dynamic-template
type ppp t-adsl
you could verify other issues if any with:
debug pppoe ev/err/pa
debug ppp nego/authen
debug radius
debug subscriber manager policy/class-eval/error
as a first step to verify the pppoe setup, the control policy execution and matching, radius interaction and pop negotiation.
cheers
xander
04-24-2015 01:32 PM
thank you Alexander, for the reply.
yes, you're right. It was my mistake in typing the configuration.
But i have some other problems. My ios-xr version is 5.1.2 and we have 32K BNG Licenses that activated everywhere, on the linecard, on the RSPs.
The pppoe sessions terminate on a 20*1G linecard and on the bundle-ether interfaces. When i check the logging history i look some errors like this:
RP/0/RSP0/CPU0:Apr 24 20:56:52.940 : PPP-MA[368]: %L2-PPP_MA-4-ERR_AAA_ATTR_IF : Bundle-Ether2.384.pppoe40424: Unexpected error encountered whilst getting AAA attribute type 210 from list: 'AAA ATTR' detected the 'fatal' condition 'Invalid or NULL Parameter in API'
Also i have a serious problem. After a few days, the device falls into crash and i can not commit any configurations and the router switchovers the Active RSP. The active RSP takes Standby role and the Standby RSP takes Active role and so many pppoe sessions disconnect.
On the device I can look errors about Sysdb. where's the problem. I have to upgrade or downgrade the IOS-XR or not?
By the way, why there isn't reload command in that IOS-XR version, i cannot find it. sometimes I have to do reboot by power off.
Please help me??!!!
04-24-2015 02:07 PM
the syslog message/"error" you reference may not be a problem per-se, I would really need to see the debugs requested to find out why sessions are not establishing.
it may be good idea to get on 513 first and the latest service pack/being smu current to make sure we're not running into anything "known".
I don't mean any disrespect here, but you are describing an issue without providing the detail necessary in order for me/us to say anything substantial. And I would really like to give you an answer to get moving forward but in the absence of any detail it is hard to "guess" where the problem may be...
To get somewhere, I would advice to:
- log a tac case
and regardless provide the details of:
- running config
- get smu current
- run a recommended release (eg 5.1.3)
get the debugs and traces minimally necessary to investigate connectivity issues, notably:
- debug ppp nego
-debug radius
-debug subscriber manager policy
debug subscriber class-eval
etc
just in order to define where the issue might potentially be...
cheers!
xander
05-03-2015 12:11 AM
05-03-2015 04:56 AM
your config looks ok for the purpose that you want.
the debugs probably require your username to be part of root-system/cisco-support so would add that to the username definition in the config.
if the sessions dont establish it may have something to do with the radius profile.
can you share your radius profile you use?
to apply qos on teh session you can either use the attribute ip:sub-qos-policy-out=<name> or you can create a dynamic template for a service and apply the qos policy underneat that service so you can use the vsa subscriber:sa=SeRVCENAME.
this way with sa service activate and da to deactivate you can nicely modify the services and qos.
I would need to see the debugs and the radius profile to see why it is not working the way we want...
regards
xander
