04-19-2015 10:56 AM - edited 03-07-2019 11:37 PM
Hello all.
I have few cisco devices at home that i am using to study from. I am using for now on this little setup a 2620XM and a 3500XL Switch. I have two vlans setup on the switch VLan10 and VLan20 using router on a stick. I have setup the inside and outside interfaces. I have the fa1/0 as my outside with a dhcp address of 192.168.1.10. I have also setup my internet router to see networks 172.20.0.0/24 and 172.20.1.0/24. I am able to ping back and forth from 192.168.1.0/24 to both networks. The issue comes when i try to apply NAT. I have tried two different setups and both have failed. I have two ping windows open on my PC on the 192.168.1.0/24 side both hitting vlan 10 and 20. Once i applied either Nat solution i lose ping on one vlan while still pinging the other, but both vlans can't go out to the internet. Below is the NAT solutions i have tried below. Also running config for both router and switch. If anybody can i assist i would really appreciate it.
NAT Solution 1
ip nat pool INET 192.168.1.10 192.168.1.10 netmask 255.255.255.0
ip nat inside source list 1 pool INET overload
access-list 1 permit any
NAT Solution 2
ip nat inside source list 100 interface fa1/0 overload
access-list 100 permit ip any any
Router config
R1#sh run
Building configuration...
Current configuration : 1470 bytes
version 12.3
service password-encryption
hostname R1
boot-start-marker
boot-end-marker
enable secret
no aaa new-model
ip subnet-zero
ip cef
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.5
encapsulation dot1Q 5 native
ip address 172.16.1.6 255.255.255.248
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 172.20.0.254 255.255.255.0
ip nat inside
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 172.20.1.254 255.255.255.0
ip nat inside
interface Serial0/0
no ip address
shutdown
interface Serial0/1
no ip address
shutdown
interface Serial0/2
no ip address
shutdown
interface Serial0/3
no ip address
shutdown
interface FastEthernet1/0
ip address dhcp
ip nat outside
duplex auto
speed auto
no cdp enable
router ospf 1
log-adjacency-changes
network 172.16.1.0 0.0.0.7 area 0
network 172.20.0.0 0.0.0.255 area 0
network 172.20.1.0 0.0.0.255 area 0
network 192.168.1.0 0.0.0.255 area 0
no ip http server
ip classless
line con 0
exec-timeout 0 0
password
logging synchronous
login
line aux 0
line vty 0 4
exec-timeout 0 0
password
logging synchronous
login
line vty 5 181
exec-timeout 0 0
password
logging synchronous
login
end
Switch Config
SW1#sh run
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname SW1
ip subnet-zero
interface FastEthernet0/1
switchport trunk native vlan 5
switchport trunk allowed vlan 1,5,10,20,1002-1005
switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
switchport access vlan 10
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
switchport access vlan 20
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
shutdown
interface FastEthernet0/24
shutdown
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface VLAN1
no ip address
no ip directed-broadcast
no ip route-cache
shutdown
interface VLAN5
ip address 172.16.1.1 255.255.255.248
no ip route-cache
ip default-gateway 172.16.1.6
line con 0
transport input none
stopbits 1
line vty 0 4
login
line vty 5 15
login
end
04-20-2015 03:42 AM
You need to change your acl because NAT doesn't usually work with "any" as the source.
I tend to use extended acls so -
access-list 101 permit 172.20.0.0 255.255.255.0 any
access-list 101 permit 172.20.1.0 255.255.255.0 any
and then use your second solution ie. overload on the interface.
If you find you cannot ping between your vlans then you need to modify the above acl to deny traffic between the vlans/IP subnets then permit any as above but it should work without doing that.
Jon
04-20-2015 05:08 PM
Thanks for the reply back on this. I got just about the same answer on another forum.
access-list 100 deny ip 172.20.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 deny ip 172.20.1.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 permit ip 172.20.0.0 0.0.0.255 any
access-list 100 permit ip 172.20.1.0 0.0.0.255 any
