04-20-2015 04:58 AM - edited 03-17-2019 02:43 AM
I need to check historic E1 utilization, any idea how to check it on CME?
04-20-2015 05:50 AM
You could probably setup SNMP monitoring but out of the box, all you can see is what is going on at the moment. I know there are also other third party programs out there that can do this as well. But if you don't already got it setup, you would be starting from a clean slate. Full CUCM you could use the CDR database to see what calls were routed over a gateway but that isn't something you have available on CME.
04-20-2015 08:05 AM
Hii Djeeraj,
I recommend you to use Cisco Prime Collaboration (new version of Cisco Operation Manger). It will save all history of E1 utilization, T1, Dial-peer and so on.
04-20-2015 04:44 PM
no need to go expensive with Cisco Prime. This is basic SNMP . anything that can poll an OID can pull this information, and obviously store it to offer historic information. Solarwinds can do it for instance. I know I have set it up in the past.
